I was cleaning my bike last night and noticed that there is some small, but non-zero lateral play with my cassette (i.e. if I grab the rim with one hand and the cassette with the other, I can rattle the cassette along the rotation axis).
I’m pretty sure that this is not good. Is it possible that with transportation + SC miles, the cassette lockring has slightly loosened? If someone has the tools, I’d like to try tightening the lockring to see if that gets rid of the rattle. Anyone want to help :)?
Some standard spacings:
70 mm Bike Friday tikit, Birdy, Breezer Itzy, Brompton front hub.
74 mm Dahon Speed front hub.
79 mm Dahon Vitesse front hub (report from reader, unconfirmed).
91 mm Low-end front hubs.
96 mm Older front hubs, especially French.
100 mm Modern front hubs.
110 mm Rear older track, coaster brake and other single-speed hubs. Also, front hubs for Downhill bikes with 20 mm axles.
114 mm Rear 3-4-speed. This is US, U.K. Same as 4 1/2 inches.
120 mm Rear 5-speed, Ultra 6, newer track hubs.
126 mm Rear 6- and 7-speed (road).
130 mm Rear 7-speed (MTB) and 8- 9- and 10-speed (road).
135 mm Rear 7- 8- and 9-speed (MTB)
140 mm Rear tandem.
145 mm Rear tandem (newer models.)
150 mm Retro-Choppers, some Downhill and Freeride models.
160 mm Rear tandem (new Santana proposed standard.)
Thanks for the tips! I’ve never removed the cassette, and I’m pretty sure it didn’t rattle when I bought it off Ben, so I don’t think it is a missing spacer issue.
Removed the cassette, and found that there was a bit of play in the freehub body. Guy from Right to Move seemed to think that it was minimal enough not to be worried about, but to keep an eye to see if it gets worse.
