It’s that wonderful time of year again, when it’s warm enough outside to start picking a fantasy cycling team for the spring classics!
Will Dennis lose the classics crown this year? Will he even participate? With 11 races, 12 riders per race, and 24 rider transfers, nothing about the classics is certain (except that Phil’s team will inevitably be called “Pedalling Vegan”).
And Philippe pulls ahead of Coach P with great showings by Sagan and Cancellara. Jordan and Master Yaoda also saw their scores increasing at E3 and Gent-Wevelgem. Will these trends continue at the Ronde?
Phil keeps his lead, but Master Yaoda is not that far behind thanks to his picks of Kittel and Stannard. Things are far from over though, as we now move into the Ardennes classics. Different terrain and different riders will warrant a change-up to your rosters, so I hope you kept a few transfers left over
If you can believe, the Spring Classics are nearly over! There has been a bit of movement in the McGill Cycling League rankings since we started the Ardennes. Coach P made some gains at La Fleche Wallonne by successfully picking 1st, 2nd, 3rd, 5th, 6th, and 12th place finishers. However, with only Liege-Bastogne-Liege remaining, it will take some outrageous fortune for him to overtake Phil’s monumental lead. If you have any transfers saved up, now is the time to use them!
